Adjusting clutch
Adjusting clutch
How do I adjust my clutch on a 2000 z28. Is it on the tranny? Or what it doesn't grab until about half way released. But I know it's not because of a bad clutch. I took it out and looked at it, it seems to be fairly new still.
Right on there is just so many things I am trying to do to that car I wish I could just come up on like 20k. 19 of it would go right into the car lol
a while back i was plague with the sticky pedal syndrome that everybody complains about. What i did was product of elimination. I started off with the easy stuff like draining and rebleeding the clutch fluid with higher temp dot 4. That didnt work so i went with the tick master. that didnt work so i went with the slave cylinder. that didnt work so i went and replaced the clutch and that worked. I also live in the bay area also
1 Post
There's a rod that comes through the firewall from the clutch pedal. It's threaded with a nut. Kinda got to adjust it in until the the clutch release feels right. Keep trying.
