Clutch issues....
Clutch issues....
Well the clutch its self isnt the issue I have a bad pedal. Typically the clutch in my 2001 Camaro ss is at the top till the other day now it is inches off the floor and then in the middle. So I assume it is master slave issues. There isnt any leaks but air in the lines or just a faulty unit I assume could be the issue. I am looking into 3 to 4 different clutch packages Monster, McLeod, Ram and diamond all in about a stage 2 setup. Planning on doing the flywheel in a 18 lb light weight and doing both master and slave. Any words of wisdom on the light weight flywheel or the brands I am looking into would be greatly appreciated.
