tick performance master cylinder vs stock??? Do I really need the tick one?
I think i'm going to replace my master cylinder to try and fix my clutch issues.. I have read a few forum members suggesting to use the tick master cylinder.
I have no intentions of upping the HP/TQ on my '00 z28 so are you sure the tick master cylinder is not complete overkill?
In the event the master cylinder does not solve my clutch issues:
Thanks
- Do you suggest LS6 or LS7 clutch package? I read something about the LS6 one being lighter. Again, I'm not going to up the HP/TQ so the LS6 one should be sufficient?
- What slave should I get?
- Is the tick performance master cylinder compatible with both the LS6/LS7 clutches?
Thanks
Do a search on what I went thru after installing a Brand new LS7 clutch, New oem Master, Tick speed bleeder. My new oem MC went bad just mainly from just bleeding it alot, and it was still on jack stands. I'm sure some have bought replacement oem mc's and they work. Mine didn't, and it wasn't a cheap one. It was from Carquest. Yea, the Tick is a bit pricey, but it works and the quality is great. Save up and bite the bullit.
As far as clutches, well that's alot of searching and it all deals with horse power. I have no complaints with my LS7. If I was going to be modding alot more than what I had done, then I would go with Monster from SNL Performance. They monitor all the threads here, and they always Help out with the ones that have problems, even if they didn't buy a Monster clutch. So they back their product. Everything I read, is most buy Monster clutches.
yes buy the tick , i just went from a failing stock with 4 yrs and 20k on it and when it was new it never shifted as well as the new tick unit.
Buy it , best mod for t56 cars.
I'm currently in the process of installing a new GM slave cylinder and a Tick Bleeder (ordered both from Tick) on my T56. The master i got is from Autozone unfortunately. Tick is def the way I would go if you have the funds. Thanks
i had my new oem master leak on me after 3 year. ordered a tick, other then a defective clutch line crimp which blew off the line, which tick performance posted about bad batch of defected crimps at the time. it was replaced under warranty. 3 years strong and no problems
Just picked up a 2000 Z with 75k mi, mostly stock, one owner. Typical clutch... First half is slop, 2nd half is pedal but it doesn't always return all the way up and it doesn't feel like its 100% disengaging.
My question is how HARD or how much "more" pedal effort does the Tick give with a stock clutch? Does the "adjustable" feature control effort at all?
Anyone able to install their 4 foot bleeder hose to the existing bleeder nipple, without pulling tranny in other words?
Thanks
Thanks
My friend bought a T/A with a Wilwood CMC for an Auto to manual swap. He hates it, it's junk, and he just bought a Tick CMC. He has one in his Camaro and can't wait to get it into his T/A. I have had one in my previous Camaro Z28 and my current Trans Am. Love it. Well worth it!
Thanks
Thanks
it takes 15 percent tick says , i installed it in mine 4 weeks ago and noticed it was more effort , but now its normal . Its not a big deal and you will not even notice. you will be too happy that you can bang gears better than ever .
and the 4 foot bleeder .i did mine when i did the clutch but , you can drill a hole with a hole saw inside the car and get to the bleeder that way . I mean the carpet covers it up when your done and you could pop rivet a plate and then seal it up and never know .
But that's the only way i know if the trans is still in .
Dam, its been 13yrs since I owned my last F body. I thought the throwout had a nipple with a bleeder on it stubbed out of the bellhousing?!
Oh well!
Once i get my shop back together after a move, i will just pull it and put in a new clutch and throwout.
Oh well!
