11" Clutch with 5.3L LC9?
Quick question regarding a clutch. We are doing a custom setup for our vehicle... The engine we have is the Erod LC9 5.3L. I am now picking out a clutch for this engine. The bellhousing we have is a Quicktime that says the max clutch disk diameter is 11". So the clutch I was going to pick is the following:
http://www.summitracing.com/parts/ra...et?prefilter=1
Is this compatible with a stock 168 tooth flywheel, or do I need a different flywheel to match the 11" clutch?
The flywheel I was thinking of getting is:
http://www.summitracing.com/parts/sum-700187
Our engine will be totally stock. If you have suggestions for different clutch/flywheel combos that maintain good drive ability, let me know. I would rather spend the money on a good product than buy something that isn't going to work well.
