How much HP is the Stock Flywheel Good For?
Old 12-07-2014, 08:43 PM
maxpower_454's Avatar
Default How much HP is the Stock Flywheel Good For?
I'm curious, how much HP is the stock cast flywheel good for?
Old 12-10-2014, 09:29 AM
Anyone?
Old 12-10-2014, 10:11 AM
guppymech's Avatar
IMO it's more of a usage issue than HP. Do you drag race with slicks? If so then you might want to get a SFI rated FW.
Old 12-10-2014, 11:48 AM
redbird555's Avatar
exactly. the stock flywheel doesnt have a hp per say rating but as you get into more stout aftermarket clutches the heat factor and aggressiveness of the clutch disk goes way up so you're better off with a billet piece
Old 12-10-2014, 12:26 PM
BALLSS's Avatar
FWIW when I took my stock FW to a machine shop for balance (neutral) The guy asked when I picked it up if I "spin it high RPM"....His opinion of it was not good.
Said the metal is low grade and when he ground down the cast in weight...no sparks, just dust.
This was a LT1 factory FW.
So as noted it really comes down to use and running a aggressive clutch disc and high RPM clutch dumps, especially if running a tire, is beyond what the FW was engineered for...IMHO
I have a SFI billet FW with my twin disc clutch now.
With all this said I have not heard of a factory FW exploding....but that does not mean it has not happened in higher HP aggressive use conditions...YMMV
Old 12-11-2014, 07:52 AM
Ok, thanks guys. I was leaning toward replacing it anyway. The rest of the car is setup for 7-800hp so I want to make sure the clutch can take it if the car hooks.
Old 12-11-2014, 08:39 AM
redbird555's Avatar
absolutely then. most aftermarket companies wont cover warranty or even sell you a clutch without a billet flywheel
Old 12-17-2014, 11:42 AM
AMP-D's Avatar
Its all about the wear capacity of the stock flywheel with more aggressive clutch disc materials. Billet steel instead of cast iron will hold up better against performance type disc. You also have less chances of the pressure plate bolt threads pulling out of the flywheel under strong centrifugal forces.
Old 12-20-2014, 06:51 PM
2nd Gen Fl 'bird's Avatar
About 100 less HP than stock.
Quick Reply: How much HP is the Stock Flywheel Good For?
