future of shifting for T56?
This could make things very interesting if it's built to handle abuse and priced to sell. Shift **** is a little ricey but the concept as a whole is cool
http://www.s1sequential.com/t56-sequential-shifter/
on the link it says:
"There are no wires to connect and no adjustments to make for a basic fitment ."
but in the pic there is a wire coming down from shift ****....so what would that wire be...reverse lockout??
I used a similar product on my old Nissan a few years ago, the idea is great but it shifted between gears so fast that the stock synchros in the box struggled to keep up, and this did cause the synchros to wear pretty quick. Would be better if you had it on a dog box. This version might be a lot better than the Japanese version I used though and maybe the T56 will take the abuse better than an old Nissan box.
From what I read on the link in the first post this does sound quite a bit better than the Jap shifter, I couldn't select neutral between gears with it just go up or down the box. N12345 and 54321N.
This maybee a dumb question but how would you down shift using this shifter would you have to come to a stop each time and and start from first,or go threw all the gears then it will begin to down shift
Andrew
I've been watching this one. Load cell **** hooked up to a lingenfelter box means full throttle up shifts. I fail to see how this will work well with a synchro equipped trans. Seems like you would need a dog box.
