T-56 Vibration and noise through shifter
Wondering if anyone has had this problem? Car shifts fine and goes into gear. I have a noise and vibration coming through the shifter under power. Almost none when temp is cold out. Hot days it is worse. Thanks for any help.
Some ideas on the link below. Is there any noise at all when the car is idling in neutral with the clutch engaged (clutch pedal up)?.....or in other words neutral gear rollover rattling.
https://ls1tech.com/forums/manual-tr...ots-ideas.html
