tick mc
tick mc
So I've read about everyone having the clutch squeak and have read every post about it. I did a spec clutch drove it on the stock McGrath with no noise as soon as I did the tick it keeps doing this I can't take it anymore. I removed the spring greased lubed everything still does it. But its more like a squeal only when I let it out. Can't be the clutch cause only started after the tick. Clutch isn't glazed I hammer on it daily. Clutch isn't slipping either. Maybe not bled right idk. Please help.
Moderator
Received 1,836 Likes
Is it a metal on metal sounding squeak or a thick "rubbery" sort of squeak? If fluids get ont he friction material, it'll make rubbing noises. I've heard of ticks popping slaves, causing fluid leaks - though I'd think that would cause other issues as well.
Yeah like thick rubber sound like a squak sound. But i know the mc isnt leakin nor motor. Its a low mileage car.
Moderator
It really does sound like fluid on the friction material. SInce you've already checked the motor and master, only thing I can think of is the tick might have overextended the slave and popped a seal. That just doesn't add up to me, because I would think you'd have shifting symptoms, but you have not mentioned any.
I assume you've tried feathering the clutch in fourth going down the highway to burn the clutch a bit. I find that helps. But I've got an oil leak, so I know why mine makes that noise.
Moderator
thanks for reporting back that it worked!
