New Clutch
New Clutch
Hey guys,
I'm planning on getting a new clutch. I have an 01 ws6. I literally have no idea where to start so any advice would be appreciated. I want something that I can still comfortably drive on the street but can still perform on a track when I take it! Also, something that is affordable, nothing too crazy expensive would be nice!
It is a completely stock car, I do not plan on doing anything super crazy to the car in the future. I just mean in relation to other clutches I don't want to spend the most on the highest brand, or buy the cheapest brand. I would like something in the middle area if that makes sense.
Moderator
Received 1,835 Likes
Monster stage 1 would be my recommendation for you.
mainly the material of the disk. stg 1 is organic (stock driveability) the stg 2 is a kevlar blend (similar to stock) and then the stg 3 goes to ceramic puck style. the pressure plates are the same the clutch friction materal is what makes them hold more power.
Monster is good, but I'll play devils advocate and say to check out Diamond clutches made by TDP as well. they are a little cheaper if you chose to reuse the stock flywheel and also have a very good rep
you can have that resurfaced most likely, the pro is much less cost. the con is that the newer clutches are much more aggressive so a harder billet flywheel is preferred. athough with stage 1 kits you probably would be just fine. monster wont sell you a kit without the flywheel where diamond will.
best bet is to give Jason@TDP and Steve@Monster a call and see what both recommend. both are very nice guys to talk to
Moderator
One thing to throw out there is the F-body master cylinder really sucks. You can replace it with a factory one, and it still sucks.
I know it's expensive ($300 vs $75), and it may not be in your budget, but I urge you to consider a tick master cylinder.
I went through several stockers in a year before sprining for the "expensive" tick unit. It only seems expensive until you've done the replacement a few times, and you start to realize your time re-replacing that master isn't worth the savings on parts.
Hey guys,
the master cylinder is what you're pushing on when you push the clutch pedal down. it pushes fluid into the slave cylinder which pushes on the clutch to disengage it. The stock one is very tiny and causes shifting problems with some clutch setups or rather most of them. The tick unit is made by tick performance with a tilton brand cylinder (top quality) and fixes all those issues due to its larger size
Also, if I put the monster stage one will I be feeling any of those problems?
pretty much that.... and no the aftermarket cltch is actually a better design and will help alleviate those problems but the hydraulics are also still an issue. f you dont race the car much you may not even notice it but its still not good lol. basically 1-2 shift will be fine then when you try to go to 3rd or 4th the pedal will lose pressure and stick to the floor not allowing a shift
Moderator
It depends. My car never saw the track, but I drive very "spirited" around town. I had zero luck with a stock replacement. Maybe your experience would be different. If I was a betting man, I'd lay money on a stock replacement not lasting.
And redbird is right about the aftermarket clutch. The stock clutch is self-adjusting, and the adjusting mechanism results in inconsistent clutch pedal travel and return. The monster behaves like a clutch should.
