clutch choices
clutch choices
Car is an ls2 swapped 4th gen. Will be H/C/I next season with a 12 bolt. I am leaning toward a monster stage 2. Does anybody have experience with this clutch on a similar setup or a different clutch on a similar setup.
So many questions left unanswered...and this question gets asked a lot, a search could help you.
How much power are you planning on making?
How much does the car weigh and what kind of gears do you plan on running?
What will be the primary use of the car? Drag/DD/Auto-X/Trackdays?
Whats your budget like?
Monster has the best warranty in the business, I just picked up their LT1-S Twin setup.
Biggest thing though is you want to get a Tick Master Cylinder and Speed Bleeder - Its worth the money.
Outside of that without knowing your power goals or the other questions above its hard to really know where to start.
Single Monster Stage 2 or 3 fit most applications, if you're on a budget an LS7 with a stock Flywheel might hold depending on how much abuse you put it through.
If you've got a slightly bigger budget the twin setups from Monster or Mcleod are well reviewed, can handle more abuse and will last longer.
Just whatever you do, don't get a Spec.
Moderator
Received 1,836 Likes
Blue nailed it, except on one point I would disagree. LS7 clutch feels heavy. I don't know a better way to describe it. Not quite as respnsive on the throttle, and it takes longer to slow back down. Almost like a truck motor.
I drove a friend's LS7 clutched LS1 when I replaced mine, and it convinced me to go monster for the lighter clutch.
Moderator
Do you know what flywheel your friend was running? A stock flywheel with an LS7, I'd assume the MOI and rotating assembly would be about the same as a pure stock LS1 Clutch from the factory, but maybe I'm wrong? The clutch is a bit heavier because of the more agressive PP but I'm trying to understand what would've caused it to feel "sluggish" when compared to a full stock setup.
The reason it would feel sluggish is the rotational inertia / momentum is higher, so it takes more energy to change the rotational speed up or down. Also, that mass is far away from the center of rotation, which means that 12 pounds makes a bigger difference than you'd think. The crank weight is closer to center than the flywheel and clutch weight.
This is one of those "I know what I'm trying to say, but I don't think I'm saying it very well" things
Didn't realize the LS7 assembly was 12 lbs heavier - That makes sense it would raise the MOI, along with (I'm assuming) he had a stock weight flywheel and where that could appear to be a tad more sluggish than stock.
