98 t56 swap Questions.
I'm halfway through the swap, and have a question about wiring. I have a harness from a 98 6 speed. What will I have to do to wire in the Reverse lockout, and is there anything that I am missing that will need wired up
Youll have to wire the neutral safety switch in with the wiring that went to the auto shifter for the car to start. Pretty simple to wire up, just been a long time and dont remember the specific wire colors. You can always just tie the two wires that go to the shifter together TEMPORARILY to get you going, but I wouldnt recommend leaving it like that.
