Monster clutch stage 3
they will all fit you just need to be sure that you get the right supporting hardware with each. personally the ls1 style is what the aftremarket companies use and is a good option. pretty much any clutch you buy, monster, mcleod, diamond, etc will all use the ls1 style flywheel
Moderator
Received 1,835 Likes
pilot bearing, GM slave, ARP flywheel bolts, Tick master cylinder, remote clutch bleeder. You can usually get it all as a kit for around $1K
