Best option for slave cylinder?
Old 04-27-2015, 01:08 AM
FCar2000TA's Avatar
Default Best option for slave cylinder?
Since my trans is out, and the slave cylinder looks pretty worn, I think I am going to go ahead and replace it. I have a McLeod Street Twin clutch. The only ones that I can find besides the basic 01-02 f-body slave cylinder are RAM Heavy Duty Hydraulic Slave Cylinder and 98-02 LS1 Ram Slave Cylinder.
inputs?
Old 04-27-2015, 04:23 PM
FCar2000TA's Avatar
Just talked to McLeod. They recommend that you have an aftermarket master cylinder OR aftermarket slave cylinder.... NOT BOTH. Since both have increased line bores, you could end up without enough pressure to work the clutch. So... I'm going with a factory 01-02 slave since I already have an aftermarket master.
Quick Reply: Best option for slave cylinder?
