T56 "reverse fix" cause reverse gear failure?
Recently I did the reverse gear fix on my T56. You shave .125 off of the front side of the reverse shift fork and put a .125 shim behind it to move it forward more. This did stop reverse from popping out of gear like it always did before. I put 10 miles on the trans like this and then the transmission locked up I tore it open last night and the caged bearing inside of the reverse gear is in a million pieces. The mainshaft is most likely toast to. I did flip the reverse gear synchro. I also put the transmission back together just like I had taken it apart. What could of cause this? Did the .125 that the "reverse fix" required crowed there reverse gear so much that it overheated the bearing inside reverse?
1 Post
Not knocking anyone here but, sounds like something happened on the reassembly. I did exactly what you did on the reverse fix but, added new blocker, fork pads and keys. Been a year and my reverse is slick as $#1+!! Spacing the fork forward shouldn't have anything to do with the bearing failure.
