Quick hydraulic question (very easy)
I am finishing a clutch install tomorrow. Would it be a good idea to lube the o ring on the hydraulic line with some vaseline or something before it gets plugged back in? Normally with o rings like that you would but I haven't seen that mentioned on any writeup I have read.
Moderator
Received 1,835 Likes
As many times as I've disconnected and reconnected my clutch line, I never have greased it
People use Vaseline mainly to hold packings in place. What you want to make sure is you don't push it in dry. You could push it out of place or scar it. I would wipe a light coat of fluid on them
