Disconnecting slave cyl line
Old 05-24-2015, 08:42 PM
David_viny's Avatar
Default Disconnecting slave cyl line
Does the line have a check ball or something to keep it from loosing all the fluid or is it going to be a shower of brake fluid everywhere?
Old 05-24-2015, 09:28 PM
Moderator
Darth_V8r's Avatar
Received 1,836 Likes on 1,145 Posts
there's an internal check valve. You're good. it'll leak a little, but not much
Old 05-24-2015, 09:57 PM
David_viny's Avatar
Thanks!
Old 05-26-2015, 10:43 AM
stevieturbo's Avatar
They're great, they rarely leak, and amazingly rarely need bled again after re-connecting unless you've done other work that means bleeding.
Quick Reply: Disconnecting slave cyl line
