Replace flywheel bolts?
Are the flywheel bolts reusable? Or should I order new ones?
And I mistakenly posted in the auto section, but is there special thread locker needed for the flywheel?
re-used plenty before, i just use some normal Wurth loctite as I have it here.
That said if you're just planning ahead, new bolts are cheap so why not replace ?
If doing it now and you have no bolts...just keep on going
I'll have to double check, but I thought my McLeod kit had ARP bolts in a bag in there (along with a few studs). I just assumed they were the pressure plate bolts
