Seized t56, re using carbon syncro's
Had a 'small' issue with my transmission, rear oil seal came out at 125mph, lost all the oil and transmission seized.
I have a spare transmission of which I 'll use all the internals, have a set of bearings, seal, clips,... on order.
My question is, the seized transmission had only a couple of 1000 miles on it, and was rebuilt with carbon syncro's, would I be ok re using these? As you'll see in the pictures there was some pretty serious heat damage, the carbon rings look OK though, no discoloration or nothing, look like new.
Ram SRT10 viper T56
Some carnage pics:
Ram SRT10 viper T56
Some carnage pics:
They might be ok. But that main shaft got ridiculously hot. If the heat treat was compromised, they may have weakened where the slider keys ride. For the cost of new vs having to tear completely down again to replace a failed blocker, it's a no brainer to me. I personally wouldn't risk using anything from that main shaft.
Thanks for the info guys, I tore down the spare T56 I have and the internals look perfect, the syncro's look identical to the carbon syncro's from the seized trans.
Can you visually differentiate the old paper vs the carbon blocker? I have a suspicion that the blockers in my spare trans were already carbon ones.
As for the cost, I live in Belgium, so when you add shipping and taxes everything starts getting real expensive real quick :-).
