LS 3/Muncie 4sp, Corvette
Old 07-12-2015, 05:42 PM
solidaxel's Avatar
Default LS 3/Muncie 4sp, Corvette
I am going to change engine in my 62 Corvette to a LS 3 and would like to keep the stock Corvette bell housing and transmission.
I understand the crank shaft is shorter on the LS, so there is a difference in the length of the trans input shaft by 1/4 inch to the pilot bearing
What flywheel and clutch will I be looking for (LS 7)?
Will the stock through out bearing and clutch fork work with the LS 7 clutch package, or what will I need?
Old 07-12-2015, 08:00 PM
S10xGN's Avatar
Prolly can't do it with the stock C2 bell. IIRC, those only fit the 153t flywheel and you'll need a bell that fits the LS's 168t 'wheel. There are factory aluminum bell options and several aftermarket steel ones...
Old 07-15-2015, 07:56 AM
garys 68's Avatar
Very doable.
All the info and part numbers you'll need.
https://ls1tech.com/forums/conversio...-ls-motor.html
Quick Reply: LS 3/Muncie 4sp, Corvette
