Adjusting the tick master
Had it adjusted about an inch under the brake and was pretty good but was worried I wasn't getting full disengagement was about mid of pedal release. Adjusted a bit more and about quarter inch under the brake now release is at the top and shifts are a little nothcy feeling
Moderator
Received 1,835 Likes
There is not a lot of free play in a tick master. I would try to make it slip before I chased it. If it won't slip, it's probably fine.
Moderator
Yep, that's the best way. You'll be in good shape
I'm in the same boat as you, it was driving me crazy and I'm OCD about everything being perfect on my car. Called up tick performance and they said as long as it is at the same height as the brake pedal or lower most cars should be fine and you aren't going to blow out the slave. Mine is a hair lower than the brake pedal and feels great so I'm going to leave it there.
I've got my pedal dead nuts even with the brake pedal, but I'd like it to be a tad lower. I've been thinking about adjusting it some. The clutch pedal had been about 1/2" above the brake pedal, and that sucked, so I adjusted it to where it is now, and it's been that way for a long time. I may play with it Friday night before going out to play Saturday evening.
^ yes, if you have the tick, and still get wheel spin with clutch pedal
pressed in, you need to adjust the rod out as you are not getting enough
disengagement to satisfy the clutch.
...may be a shim issue as well, and not sure if adjusting the tick out more
would help that. my simple brain says it would to a point, but that depends
on how much of a shim you may have needed.
