Mgw problems
Old 07-28-2015, 12:02 AM
leonrvn's Avatar
Default Mgw problems
Just ordered and installed new isolator cup (the plastic one) when I have the mgw shifter and try to drive aggressive the ball is popping completely out of the cup after a hard shift ,, the shifter Is screwed down tight ,,, tried the aggressively shift with a pro 5.0 and it works fine ,, what is the problem with the mgw ? Has anyone had this happen to them before ? How can I fix this ???
Old 07-28-2015, 11:16 AM
guppymech's Avatar
Check out these recent threads fo some info:
https://ls1tech.com/forums/manual-tr...p-damaged.html
https://ls1tech.com/forums/manual-tr...hift-cups.html
Looks like some people have issues with the MGW, when I had one it worked fine.
Quick Reply: Mgw problems
