Trans fluid smell only while driving?
For some reason my car has faint smells of the Redline fluid I put in but only while driving and only while in 6th gear. RPM and speed doesn't matter, if its in 6th and moving I get fluid smells and sometimes they are pretty strong. No smell in the garage and no leaks on the floor either.
I put in the required 4 qts of fluid and also used black rtv on the shifter base (MGW). The rtv made the situation better but it still happens. I also can't tell if it gets better with the windows up or down.
I currently don't have access to a jack to get under the car but with there being absolutely no smell in the garage and no drops on the floor I can't think its leaking?
