Pilot Bearing Welded to crank?
Old 08-12-2015, 11:14 AM
stang_kllr's Avatar
Default Pilot Bearing Welded to crank?
So I'm doing some work for a guys Camaro. 99 z28 M6. Im swapping in an ls7 clutch, tick master and a ram slave. I got the trans and all out but im having extreme trouble with this pilot bearing. The trans input shaft has soo much play it destroyed the pilot bearing and now I cant get it out to replace it. It seems like it just got soo hot that it welded itself to the crankshaft. I tried using the pilot removal tool and broke one of the fingers. I tried another and still no luck. It grabs behind the pilot but when I use the pulley to pull it out, it slowly just grinds off the metal and doesn't budge the bearing at all. I feel like my only option left is to try using a die grinder, but I don't want to risk messing up the crank. Does anyone have any suggestions? anyone deal with this before?
No chucks came out, only metal dust.
Old 08-12-2015, 11:46 AM
Zmg00camaross's Avatar
Mine was pretty similar. Also broke a finger off the puller. Used a carbide bit and cut into it and used a chisel and once I broke that tension it came out. Now when I was cutting into it I did get into the crank a small amount. I deemed it ok and drove the new bearing in and been like that for years and a bunch of track passes.
Old 08-12-2015, 12:41 PM
BALLSS's Avatar
I found this blind hole puller from AutoZone loan a tool worked very well....although my pilot bearings have not been like OP's
the cut/chisel method may be needed but if the tool is available near you, worth a shot
Attached Thumbnails Pilot Bearing Welded to crank?-pilot-bearing-puller-27128.jpg
Old 08-12-2015, 01:37 PM
stang_kllr's Avatar
Ah man that's good to hear. Thanks for the info man ill try it out. I was just real worried about screwing up the crank and having to pull the motor. Ill try it out today and keep you posted how it turns out man.
Old 08-12-2015, 01:38 PM
stang_kllr's Avatar
Thanks man. yea Oriellys has something similar to that one, but I used a puller style because I don't want to damage the thrust bearing using the slide hammer.
Old 08-12-2015, 01:47 PM
Just take your time and hit it with a hammer and chisel where you are cutting into it and usually you can crack them and they will come out. May take several times hitting and cutting etc.
Old 08-12-2015, 02:14 PM
stang_kllr's Avatar
cool man, yea after a couple beers, im pretty patient lol
Old 08-12-2015, 04:00 PM
stevieturbo's Avatar
dremel or similar tool and grind away one side and that will release the tension and allow it to come out easily.
Old 08-12-2015, 04:22 PM
hrcslam's Avatar
Same here I had to chisel mine out too. Seems common for the needle pilot bearings. I went with the pilot bushing when I replaced mine so I could use the blind hole puller next time.
Old 08-12-2015, 04:36 PM
Ls1tech & Truck Sponsor
NitrousExpress's Avatar
I too had the same issue when going from LS7 clutch to my new spec one. My fix was the same fix as others have posted.... Drill - Grinder - air hammer - chisel
-Chris
Old 08-13-2015, 07:13 AM
stang_kllr's Avatar
Awesome thanks fellas! it ended up coming out fairly easy after I grinded off one side then I used a chisel. No damage to the crank.
[IMG]https://cimg8.ibsrv.net/gimg/ls1tech.com-vbulletin/540x960/80-
pilottt_7229888a529d7ca76bb43347d88a3a89449ba338.j pg[/IMG]
Old 08-13-2015, 07:14 AM
stang_kllr's Avatar
Quick Reply: Pilot Bearing Welded to crank?
