Corvette T56 Main Shaft Options
Old 08-25-2015, 08:35 PM
About2Bite's Avatar
Default Corvette T56 Main Shaft Options
I have a 99 c5 and am looking at a couple main shaft options
First, g-force 9310 27 spline main shaft
Second, 30 spline oem c6z06 main shaft. If going this route what is involved in making it work? Machine pinion gear, etc? Is a 30 spline pinion available?
Which option did you go with and why?
Thanks!
Old 08-26-2015, 05:38 PM
jmd
jmd's Avatar
Did you have a failure?
if your main shaft snapped because of wheel hop, that needs addressed.
I prefer the 30 spline; the G-Force rev. gear bearing setup is unique.
RPM can help with the pinion gear.
Old 08-26-2015, 08:12 PM
About2Bite's Avatar
No failure. I have the transmission apart for a rebuild and am upgrading parts as I go. The main shaft is on of the parts that I need to replace and I figure I ought to upgrade it.
I plan on 3.90 or 4.10 gears so I can modify the pinion at that time.
Just looking to see what others have done.
Old 08-27-2015, 09:52 PM
AMP-D's Avatar
I do not think the G Force shaft is currently available.
Quick Reply: Corvette T56 Main Shaft Options
