T56 fluid
Old 09-05-2015, 04:14 PM
blkbowtie98's Avatar
Default T56 fluid
Whats the best t56 fluid to use for a 2002 WS6?
Old 09-05-2015, 05:25 PM
murphinator's Avatar
tag right on the trans says dexron 3 atf , if its stock with the paper blocker rings I wouldn't use anything else... if it has been upgraded then there many other fluids that will get tossed around in these conversations from synchromesh to all the aftermarket quality synthetics.
Old 09-05-2015, 05:46 PM
XDeath's Avatar
Stick with AC Delco part number 88861800 from the dealership. It's the oem replacement for dextron iii. Might cost an arm and a leg, but is definitely worth it. Was using it for the lifetime of my '99 z28's t56 until i switched to royal purple and destroyed my trans..
Also dextron vi can be used in replacement for dextron iii.
Old 09-05-2015, 09:36 PM
dailydriver's Avatar
Was the RP that killed your Tremec their Synchromax manual trans fluid stuff, or their synthetic Dex 3 ATF??
Also, the Dex 6 stuff is WAY TOO THIN for use in a T56, unless you live inside the Arctic Circle, in the winter time!!
Old 09-06-2015, 08:14 AM
1995_maro_z's Avatar
I just use regular dex 3, available at any parts store.
Old 09-06-2015, 07:18 PM
Firebrian's Avatar
Tremec's recommendations as of a couple years ago were Dexron ATF 3 or Mobil 1 synthetic ATF. Those were the only ones they claimed had enough data to show they worked properly. If you review older threads you'll find everything from Synchromesh, Amsoil ATF, etc. You should not have the paper block rings in your 2002, unless some rebuilt the trans with older materials only seen in stock '98's to 00's.
ATF 3 is simple and it works, just like the label attached to your transmission recommends. I put in regular Valvoline ATF 3 when I did mine as I don't race or track my car. For a car that is sometimes tracked or run hard in hot weather there might be some advantages to higher end products. I must have read old threads on here for hours before I finally came to the conclusion that ATF 3 was the safest and most logical choice for what I do. And my trans has the paper blocking rings that could swell under the wrong type of fluid. The factory fluid had been in my car for 13K miles/13 years. After changing it out I felt or heard no perceptible difference in performance. Some people report notchier cold T56 operation with some of the synthetics....once warmed up it's fine.
One source recently told me that the paper/cellulose blocker rings on the 1998-2000 Tremec T56 manual transmissions are actually made of kevlar/graphite/cellulose composites, similar in composition to some clutch disc material. It's not quite just "paper."
Old 09-08-2015, 02:41 PM
That might be because they were using the synthetic MANUAL trans fluids almost all (except for a few Euro/Aussie brands) of which are thicker when cold OR hot than even mineral based Dex 3 ATFs.
The synthetic based ATFs should NOT be any notchier, or grind any more than the mineral based ATFs, regardless of blocker ring material.
Old 09-09-2015, 07:54 AM
dgcustomz's Avatar
Dexron III Atf and have never had any issues. Those using thicker oils is to quiet down problems that will eventually come out anyways.
Old 06-11-2016, 08:26 PM
Firebrian's Avatar
Just did a 5K mile/4 year trans fluid change on my '99 SS and went with the GM 88861800. One of my local auto shops had it for around $6/qt which was fine for me. I did plenty of research again and decided not to go with a synthetic or a synchromesh because of the cellulose composite blocker rings in my syncro's.
I reviewed a UOA on a 6 speed Vette using ATF and that sheared down quite a bit in under 10K miles (operating viscosity of 7 cSt to 5 cSt). DEX VI (ATF LV) or Valvoline Max Life ATF have viscosities of around 6.0 cSt which is too thin imo. While the dedicated MTL's have a stronger AW and EP additive packages (and viscosities of 8 to 12), some of them can interfere with efficient synchro operation and wear. The best AW packages seem to be in the Amsoil, Redline, Honda, Mobil 1, and other boutique ATF's. Since I'm changing out in under 5K miles, I'll stay with the GM stuff for now.
Fwiw, I saw no difference in operation from the 5K mile Valvoline conventional Dex 3 and the newly installed GM 88861800.
Old 06-12-2016, 08:46 PM
blackandgold's Avatar
Stick with Dex 3 if you're unsure. I run pennzoil synchromesh after switching from Mobil ATF in my rebuilt trans, it feels 10x better, but that's just my opinion.
Quick Reply: T56 fluid
