Let's talk about lightweight clutch/Flywheel combo's - Page 5 - LS1TECH
Thread Tools Search this Thread
Old 11-21-2015, 06:10 PM   #81
scotty2000ss's Avatar
Quote:
Originally Posted by JimMueller View Post
How much thermal mass do you need in a clutch to offset the heat generated in daily traffic jams? There has to a point where it's too small and destroys the clutch in short order even if the friction release is smooth.
Never thought of that... I'd hope the lightweight combo wasn't for a daily driver.
I wonder how quickly it would heat up in traffic?
scotty2000ss is offline   Reply With Quote
Old 11-21-2015, 06:49 PM   #82
HioSSilver's Avatar
My 5.5 tilton does fine in traffic. Heat don't seem to be a issue.
HioSSilver is offline   Reply With Quote
Old 11-22-2015, 06:17 AM   #83
Quote:
Depends how bad the driver is.
stevieturbo is offline   Reply With Quote
Old 11-22-2015, 04:44 PM   #84
Quote:
So it is NOT an "on/off" switch, like so many small diameter racing clutches we hear about that burn up on ONE try getting the car onto a trailer??
dailydriver is offline   Reply With Quote
Old 11-22-2015, 05:13 PM   #85
Heat will always be more of an issue on smaller diameter clutches.
But as long as it isnt a retard driving it, there shouldnt be an issue.
If you arent capable of driving a car onto a trailer without excessively slipping the clutch, either take driving lessons, get a different trailer or use a winch.
Old 11-23-2015, 09:58 AM   #86
JimMueller's Avatar
I'd want a reasonable solution which doesn't require an expert at shifting that type of clutch. I don't want to damage a daily driver clutch just because someone who is comfortable driving a 'normal' clutch cannot shift like Ayrton Senna.
JimMueller is offline   Reply With Quote
Old 11-23-2015, 12:22 PM   #87
Changing gear isnt complicated or difficult. Like really...WTF do you think is involved changing gear ?
Foot on clutch, change gear, foot off clutch. There isnt any need to complicate such a simple task.
Old 11-23-2015, 12:31 PM   #88
You win the internet today
Old 11-23-2015, 01:58 PM   #89
The lightest clutch assy's generally won't have enough thermal capacity to slip for very long at WOT, so they are not going to be a good choice if quick 60's are your goal. With a properly slipped clutch of sufficient capacity, you’ll get your best launch while putting no more stress on your drivetrain than if you were roll racing.
weedburner is online now   Reply With Quote
Old 11-23-2015, 02:27 PM   #90
Quote:
Why wouldn't proper throttle management with the appropriate wheel/tire combo be sufficient for great 60' times with the clutch not slipping? Even if you had street tires I would rather spin them rather than the clutch, but that's if you had no throttle management skills at all. That's why a lot of guys leave just off idle with street tires, no?
North*power is offline   Reply With Quote
Old 11-23-2015, 02:50 PM   #91
Quote:
Because the reality is the huge difference between engine rpm vs wheel rpm at launch, and rpm needed to maintain a hard launch vs blowing teh tyres off....that slip has got to happen somewhere.
If the tyres slip, generally you're losing traction and hence forward motion. If the clutch slips you are putting huge amounts of heat into the clutch reducing its lifespan.
Somewhere in the middle is a balance, but there will be slippage somewhere for optimal launches.
That's why autos are so easy to launch, they've slip in the drivetrain pretty much built in, which allows the tyres to retain more traction.
Old 11-23-2015, 03:11 PM   #92
Darth_V8r's Avatar
Define thermal capacity please
Iron has a higher specific heat than Aluminum, but aluminum will also radiate heat faster. And what about Carbon? Carbon is lighter than any of them, but it doesn't melt until 6400*C, at which point it will sublime (direct phase change solid to gas) typically rather than melt. If you're seeing that kind of temp in your clutch, you'll burn your car down, negating the need to worry about the clutch, right?
Long way to ask, but is weight and diameter the only consideration, or does material selection figure into this?
Darth_V8r is online now   Reply With Quote
Old 11-23-2015, 03:21 PM   #93
Throttle management isn't a good plan if you are looking to produce the maximum amount of power possible, compressed into the shortest period of time.
Old 11-23-2015, 03:36 PM   #94
Quote:
Originally Posted by Darth_V8r View Post
Define thermal capacity please.
Having enough mass to meet slip requirements without overheating. By slipping a clutch you are basically turning more of your engine's output directly into heat, but that amount of energy you are "wasting" thru the clutch is exceeded by the added power produced by operating at a higher rpm...result is a net gain in power available to move the car down the track.
Old 11-23-2015, 05:20 PM   #95
Are most of you against the lighter set up?
Old 11-23-2015, 05:45 PM   #96
Nothing against a "lighter" setup, depends what the heavy setup was in the first place and how light you are referring to.
I personally would never go to a clutch as small as 7.25 if it was on a very heavy vehicle.
Which is the other aspect....if it is a heavy vehicle with tallish gearing as almost all LS cars are, that virtually wipes out any potential benefits from a light setup because in the grand scheme of things it makes **** all positive difference.
Old 11-23-2015, 05:52 PM   #97
Less MOI is better, as long as temp stays under control. Quick times at the dragstrip are going to require a lot of slip, so the lightest clutch/flywheel package likely won't be the best choice if that's your focus.
Old 11-24-2015, 04:56 PM   #98
HioSSilver's Avatar
I made 16 or 18 passes last time at the track. I hot lapped the **** out of the car. Heat is not a issue......and I've had no issues loading in on the trailer when used.
If you burn up a clutch loading the car on a trailer you're a idiot.....just that simple.
Old 11-24-2015, 05:12 PM   #99
Good info Hio. I saw a trailer that comes with a wench the other day. I can post the link if anyone needs it.
Old 11-24-2015, 05:19 PM   #100
If you are 10.9 @ 129, i doubt that clutch is slipping enough for a good 60'.
Related Topics
Thread Thread Starter Forum Replies Last Post
Need lots of advice on an L33 build going into an E36 M3 squashman702 Generation III Internal Engine 7 02-05-2016 03:46 PM
Which Flywheel? Redneck Z Manual Transmission 21 02-23-2010 09:18 PM
lightweight flywheel w/ procharger??? sixpack_2_go Forced Induction 3 01-30-2010 04:03 PM
Any of you LS7 clutch guys using a non oem ls2 flywheel? 2kblackgtp Manual Transmission 9 08-14-2009 12:37 AM
whats the deal with lightweight flywheels? BigPlanTransAm Manual Transmission 3 06-23-2003 04:15 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
