Removing pilot bearing
Old 11-29-2015, 07:01 PM
showdog75's Avatar
Default Removing pilot bearing
How does one remove a old pilot bearing to replace? 2006 gto ls2 if it matters.
Old 11-29-2015, 07:10 PM
ls1_299's Avatar
With a pilot bearing puller and a slide hammer. I think any auto parts store will loan them like autozone or advance.
Old 11-30-2015, 12:39 PM
BALLSS's Avatar
I use this one from Autozone loan a tool. Blind hole puller. I use a short piece of wood closet rod and a BFH to drive in the new one
tool 27128
Old 11-30-2015, 02:12 PM
Chris Paveglio's Avatar
EDIT: OOPS TOLD NOT TO DO THIS > Smooshing a piece of bread in will slowly push it out. Grease too. Look on the YouTubes for some demo vids.
Old 11-30-2015, 08:24 PM
S10xGN's Avatar
Don't do this on an LS! There's a cup plug in the back of the crank that will be dislodged into the crankcase, also causing a big engine oil leak all over your new clutch...
Old 11-30-2015, 09:41 PM
BALLSS's Avatar
^^^^^^^^THIS!!!!!
OP
AS MENTIONED THERE IS A FREEZE PLUG WHICH CAN (READ WILL) PUSH IN BEFORE THE BRARING IS PUSHED OUT....AND YOU WILL HAVE TO OPEN UP THE MOTOR TO FIX THAT.
Older Gen SBC yes, you could use the grease/bread/wet toilet paper method
Old 12-01-2015, 11:08 AM
Thanks for the correction! I did not realize this, and I was going to do this in a week.
Quick Reply: Removing pilot bearing
