2 clutch slaves bad after rebuilt transmission
As stated. I got my transmission rebuilt installed and went through 2 clutch slaves in 3000 miles. It have a monster clutch installed so i wouldn't think i need a shim. And the other slave was good for 20k miles before the rebuilt
Almost does sound like you're forcing the slave to work beyond it's normal range of travel rather than any fault.
Is it the correct slave, and is the clutch correct for your setup ?
The first was from monster that came with my stage 2 clutch. Lasted about 20k miles then completely went out at once. The 2nd was duralast from autozone. And after about 1000 miles started slowly leaking and progressively got worse. Didnt think i needed a shim for a monster clutch. Should i adjust the master?
I had the same exact issue as you are. Built trans with monster stage 3 and went through two slaves. On the third slave I took time adjusting the CMC and didn't have any issues after that. My clutch did not need shims. Monster claims they don't so I never checked.
