Cant get Clutch???
Cant get Clutch???
Okay! I doing a T56 swap on my 02SS.
Here is the Link to my build thread:
https://ls1tech.com/forums/chevrolet...lots-pics.html
I have a new Master Cyl, Rursed the Old Slave I modified to work with the triple disc clutch I have (Textralia) and reused the clutch Line. Its in good condition.
No matter what I do, I cant get clutch. Ive mity Vacd it, turned the bleeder . etc... Bench bled it. I CANT get clutch.. Pedal is justdead. Ive tried 3 different master Cylinders.... I'm LOST lol any help is Appeciated!
Try undoing the quick disconnect fitting and manually bleeding that side first.
ie push the centre to open it to allow fluid to pass to bleed it. When it's bled and the fitting is closed, pedal should be rock solid. The connect it to the slave and bleed slave as normal.
If you cannot get a rock solid pedal with the line disconnected, then you need to resolve issues on that side
