LS7 Clutch will not fully disengage (another one i know)
Old 09-22-2016, 11:38 AM
cosbysweater's Avatar
Default LS7 Clutch will not fully disengage (another one i know)
So I'm having a extremely frustrating issue with my Clutch right now, I am just about finished with the car and this is the only thing really holding me up now. So the Engine is just your standard 2002 LM7, American powertrains T56 magnum, I have a ls7 clutch, fw and pp. I torqued the pressure plate properly and used all new arp hardware. I used a fbody slave that was new and a wildwood cast master cylinder, 3/4 bore, 1.40 inch stroke. I bled the clutch and have no air in the system. When I depress the clutch its extremely stiff but it moves all the way to the floor, but it will not completely disengage the clutch. I can bump the starter with the clutch pedal depressed and the car will lurch forward. I can start the car in neutral with no issues. I read a lot of threads on here about the pressure plate being a issue but it seems like you could feel that in the pedal immediately. I just did a clutch master and slave cylinder in my 1994 corvette with the power bleeder with no issues. is there something off in my combo? thanks for the help guys
Old 09-23-2016, 07:56 PM
Project GatTagO's Avatar
Received 1,386 Likes on 875 Posts
What vehicle is this installed in?
Andrew
Old 09-24-2016, 05:22 PM
Andrew
1979 volvo 244
Old 09-24-2016, 10:17 PM
Moderator
Darth_V8r's Avatar
Received 1,835 Likes on 1,145 Posts
Sounds a lot like it needs a shim to close the gap between the TOB and PP
Old 09-25-2016, 09:58 PM
yea it does :/ i yanked the trans out and measured it up, it needs the .180 shim
Quick Reply: LS7 Clutch will not fully disengage (another one i know)
