LS7 clutch wearing behavior after 1 year
Old 11-30-2016, 01:49 PM
Choppy_Idle's Avatar
Default LS7 clutch wearing behavior after 1 year
Dear fellas!
Who has inspected his LS7 clutch after installing maybe 1 year?
I did it today and found this:
What about the fingers from pp and the 3 which are deeper then the others, did it say something about the right preload from the slave, is the contact surface normally in wearing?
It looks like the most contact surface is on the outer rim, there is the most wearing and surface from lathe machining complete gone!
Looked with a straight edge and a feeler gauge, that all surfaces are concave about 0.3mm on pp side and 0.15mm on flywheel side, is that normal, canīt believe that?
Thoughts???
Regards,
Ronald
Quick Reply: LS7 clutch wearing behavior after 1 year
