Clutch pedal travel sensor for Gen 4 F-body
Old 02-27-2017, 08:05 AM
Maxx's Avatar
Default Clutch pedal travel sensor for Gen 4 F-body
Has anyone tried installing a clutch pedal travel sensor on a gen 4? Stock we get the pedal switch, but looking to retrofit or fab a travel sensor. I think it would be great for logging at the track. Anyone tried it?
Thanks for any feedback. Tired to search the forums and no luck.
Old 03-01-2017, 08:01 AM
Maxx's Avatar
Ideas anyone?
Old 03-01-2017, 05:17 PM
imma_stocker's Avatar
I don't understand what you're trying to accomplish.
We have 2 sensors for the clutch. Top sensor at pedal's resting position and bottom sensor at the floor.
Old 03-01-2017, 05:27 PM
Maxx's Avatar
So at the track when I'm logging a pass and looking all the data available, it would be great to have clutch pedal travel data similar to the TPS. So wondering if anyone has tried to install a position sensor on the clutch pedal that could read from 0-100% instead of just engaged and not engaged. With a twin disc and an adjustable master cylinder I think this data would help troubleshooting.
Old 03-01-2017, 06:03 PM
Project GatTagO's Avatar
Received 1,393 Likes on 879 Posts
Surely there is a lever type sensor that has a 0-5 volt output that can be adapted. Look at what people are using for shock travel sensors.
Andrew
Old 03-01-2017, 07:52 PM
Maxx's Avatar
Great idea! I'll look into those. Thanks Andrew.
Old 03-02-2017, 10:37 AM
Maxx's Avatar
Found one. Anyone looking to do the same thing, check out:
http://www.advantagemotorsports.com/Sensors.htm
Old 03-02-2017, 11:03 AM
Those looks expensive. Why can't you adapt a regular TPS? They are 0-5v rotary sensors.
Andrew
Old 03-02-2017, 02:56 PM
Maybe a fuel level sender from whatever's cheap? Basically just a rheostat with harness anyways.
Old 03-03-2017, 07:28 AM
Maxx's Avatar
Andrew: I think the linear will be easier to mount, but yeah a little expensive.
imma_stocker: Interesting idea too. I'll do some research on that. Thanks.
Old 03-03-2017, 02:45 PM
stevieturbo's Avatar
Some Mercedes cars use a linear sensor for their DBW pedal sensor.
Or you could probably adapt a non linear type sensor, lots of cars these days with xenon headlights have suspension height sensors which could be adapted.
Or the simplest of getting some sort of reading, a pressure sensor on the hydraulic line. A 0-50bar sensor should cover almost any clutch type.
Although really...what are you trying to achieve or learn from it ?
Quick Reply: Clutch pedal travel sensor for Gen 4 F-body
