Shifter bolt size?
Shifter bolt size?
Anyone know what size bolts and length that hold down the shifter down to the trans. In the process of getting the pro 5.0 back on the trans for some reason the bolts won't screw with starting to bind. Trans was just rebuilt.
Thanks
Thanks
From what I know these were the originals when I pulled the trans and motor. I set the bolts with the shifter but seem to be wrong. I have cleaned the bolt threads and the trans is a rebuilt. The holes look good. I may have accidentally placed these bolts with the pro 5.0 shifter.
