why do people bash ls7 clutch/fly in an ls1 t56. enlighten me! - Page 4 - LS1TECH
Thread Tools Search this Thread
Old 03-08-2017, 04:52 PM   #61
Project GatTagO's Avatar
Quote:
Originally Posted by scotty2000ss View Post
Did you do a 10 second burn out and launch at 5500?...
I've been to 2 Holley LS Fests with my Cougar and I do this all weekend long. Easily a dozen passes, some being back to back. Burnouts don't abuse the clutch if you know how to drive. High RPM launches can heat up the clutch, but that depends on the level of slipping the clutch at the launch.
My personal opinion is that most clutch issues (regardless of brand) are predominantly self inflicted due to a lack of basic knowledge.
Andrew
Project GatTagO is offline   Reply With Quote
Old 03-08-2017, 05:00 PM   #62
scotty2000ss's Avatar
Andrew
That's it, I'm just terrible driver along with everyone else who has came across this.
scotty2000ss is offline   Reply With Quote
Old 03-08-2017, 05:47 PM   #63
JD_AMG's Avatar
I'm sure the heat was the biggest factor. The unit is also self adjusting from what I've read which is another problem.
What im getting as is what is the heat actually mechanically doing to have the clutch acting that way? This all sounds like hydraulic/slave related problems to me, and not the actual clutch itself.
JD_AMG is offline   Reply With Quote
Old 03-08-2017, 05:50 PM   #64
I said most, but if you feel this way, it might be true. It's not just driving, but also proper installation and testing. On top of that, people start mixing and matching parts without fully understanding why. For instance the prevent theory about hydraulic fluid turning black is that it's being contaminated with clutch dust. This is absolutely ridiculous, but people repeat it over and over again, until it becomes "truth."
Andrew
Old 03-08-2017, 05:51 PM   #65
Mappinsj's Avatar
My tick master is pretty good. No complaints here. except for PITA installation complaints. But that is GMs fault.
Mappinsj is online now   Reply With Quote
Old 03-08-2017, 05:56 PM   #66
landstuhltaylor's Avatar
Texas Speed sells a stock master with an adjustable throw...
Quote:
Originally Posted by 79_T/A View Post
Or just order a smaller bore tilton master cylinder like 3/4 or 5/8 and swap out the 7/8 that comes with the tick.
When I bought the tick I was chasing an issue which I initially thought was the stock master being too weak. Now that it's sorted and working I don't have any desire to pull it apart again.
That said, next time the engine is out I'll probably dig up that stock master I have laying around and weld a threaded rod to it to see if I like that better.
landstuhltaylor is offline   Reply With Quote
Old 03-08-2017, 06:00 PM   #67
Quote:
What's your best ET? Show us some slips
Old 03-08-2017, 06:02 PM   #68
Mappinsj's Avatar
I just installed it, but will post when it runs down track
Old 03-08-2017, 06:10 PM   #69
Nice. Good luck!
Related Topics
Thread Thread Starter Forum Replies Last Post
LM7 Block, 243 Heads SSweet98SS Generation III Internal Engine 13 12-27-2016 03:22 PM
Hig torque clutch? Mcload RXT fried Mar10n Manual Transmission 14 01-07-2016 11:01 AM
Clutch advice showdog75 Manual Transmission 1 09-27-2015 11:55 AM
445 ls7 605/559 RWHP/RWT N/A - 736/646 Engine Dyno ramairws6 Dynamometer Results & Comparisons 45 10-18-2011 11:53 PM
Which twin disc Orange Juice Manual Transmission 7 08-28-2010 06:36 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
    Get answers from community experts
What's your question?
Send
