help with wiring on a4 to m6 swap 02 z28
So i am attempting a swap to m6. I am not sure how to go about the wiring. I have a write up for this however am still confused. i am told for my car with hood release to connect the orange wire with a black stripe to "the black wires". I feel this is a bit vague. where am i looking for the black wires. Under the dash or in the console area. Connect the purple with white stripe and the dark green. Like 10 shades of green on here. Which one is it. Where am i looking. under the dash or under the console. I understand many of these come off the six wire plug under the console but there are no instructions as to where exactly the splicing happens. If anyone can help id appreciate it. Please send pictures if you can and plenty of moral support.
You are better off searching the transmission section sticky threads.
Basically you will need to wire the brake pedal switch and the clutch switch to the shifter switch, you will also need to wire the reverse lights to the shifter switch.
It sounds like a pain but you can find the wiring diagram and it will make more sense
https://www.google.com/search?q=a4+w...ch.com&imgrc=_
It would not be a time effective use to swap the harness. The diagrams make it seem complicated, but the hard part is really just transferring the printed diagram into your mind to think what wires you need.
I did my swap and also swapped to a manual engine harness, that too was a waste of time because you still need to wire the reverse light and all interior wiring to complete the swap. So basically I still need to manually add my reverse lights to the interior harness
