Clutch Chatter...when turning?
Old 08-28-2004, 05:06 PM
pacmantravis's Avatar
Question Clutch Chatter...when turning?
I only have around 300 miles on my Spec 3 and it has some chatter, but nothing that is too annoying.
I just notice that whenever I am doing slow speed turns (U-Turns, Turning In Parking Spaces) the chatter gets worse. Almost as if my rear end was hopping. I have to really rev the car (about 2500 rpm) to get it to not chatter when I turn.
Is this normal? Is it something other than the clutch?
TIA
Old 08-29-2004, 03:38 PM
To The Top...
Also, the chatter is only apparent while engaging the clutch. Once the clutch is fully engaged there is no noise no matter what speed or direction I go.
Old 08-29-2004, 04:08 PM
SSactionLs1's Avatar
try rebleeding it. I made a post about this a while a go but got no responces.
Old 08-29-2004, 06:51 PM
1ScrudeDude's Avatar
I have a different theory.
When you are turning your car while actuating the clutch, you put more load on it (more resistance from the front wheels being turned.)
I made the same observation with my Spec 3. Go higher with the rpms, like you already mentioned...
Old 08-30-2004, 12:37 PM
Default I think Youre Right
I think the "rolling resistance" theory is true.
No more chatter at all after a few 5k rpm clutch dumps.
Old 08-30-2004, 01:51 PM
badhoopty's Avatar
guys, what exactly does clutch chatter sound like?
i have a sound only when real slowly taking off in 1st and 2nd that sounds like a marble slowly rattling around in a coffee can. it annoys the hell out of me not knowing what that noise is.
Old 08-31-2004, 08:16 AM
You'll know it if you got it. You will feel it as much as you can hear it, the car shudders as you take off.
Quick Reply: Clutch Chatter...when turning?
