Need help with weird spec clutch problem!
I bought the spec stage 3 clutch for my 2000 Vette and initially it would have 2 different problems. At first the clutch pedal would stick to the floor after a big burn out, or when raced down the drag strip hard. Then I noticed that sometimes the RPM's would go up but the car would not move any faster (as if the clutch was slipping). Now, 2 months down the road, the clutch pedal is butter half way down and sometimes I have to pump the clutch to get the car into gear. It also will jump forward if I rev the car while the clutch pedal is pressed and the transmission is in gear (like the presure plate is grabbing the flywheel)! Very Weird! I have not replaced the master or slave cylinder and plan on doing so soon. I have also heard of the drill mod for the master cylinder. Any advice on what the hell is going on, or what I should do would help. I'm at the point of ripping the spec clutch out and replacing it with the Mcleod Clutch while installing better master and slave cylinders. I have heard its hit and miss with these clutches and the master cylinder is a must to upgrade!
That's what I kinda thought! So do you think it would be alright to keep the spec 3 clutch installed, Or should I replace it when I replace the master and slave cylinders?
Try an Exedy clutch. With this clutch there is no need to upgrade hydraulics. Alot of the Vette guys are running these clutches. I have one and love it. The single disk holds 600 ft/lbs and the twin holds alot more! Extremly smooth clutch, and again due to their design there is no need to upgrade hydraulics.
wrencher
Originally Posted by ashade98
Try an Exedy clutch. With this clutch there is no need to upgrade hydraulics. Extremly smooth clutch, and again due to their design there is no need to upgrade hydraulics.
