slave is out and on my desk, which one is it? update or no? - LS1TECH
Thread Tools Search this Thread
Old 12-15-2004, 02:16 AM   #1
That's what she said...
TheBlurLS1's Avatar
Default slave is out and on my desk, which one is it? update or no?
how do i tell if it's updated or not??
there doesnt seem to be a part number on it, only some wierd markings and the number 13. there is also what looks like a production date marking but im not sure. its 2 circles, one inside the other, between the circles is a bunch of dots, and in the center is the number 01. maby it is a 01 slave? maby not? i thought i remember seeing a rubber sleeve over the spring on the new slave when we bought it.
my mom picked it up from a clutch shop, so i dont know if its updated or not.
is there any visual difference between the two??
here's a picture i took with the camera on my phone lol hope it helps
slave is out and on my desk, which one is it? update or no?-slavecylinder.jpeg
TheBlurLS1 is offline   Reply With Quote
Old 12-15-2004, 07:57 AM   #2
Easiest way to tell is by checking the size of the bleed valve. If it is 7/16", you have the updated slave. If it is 8mm, then you have the old version.
NOBR8KSS is offline   Reply With Quote
Old 12-15-2004, 01:01 PM   #3
TheBlurLS1's Avatar
thats just the kind of info i was looking for!! well i had been using an 11mm to bleed the sucker so i guess it's a 7/16" bleed valve.
can anyone else confirm this? i want to make DAMN sure i dont put an old style one back in, i've got enough problems and dont need that one!
Old 12-15-2004, 10:50 PM   #4
TheBlurLS1's Avatar
ttt for me, can anyone else confirm what nobr8kss said???
Old 12-16-2004, 10:46 AM   #5
What NOBR8KSS said is correct.
But depending on how much abuse you put on it , You might should go ahead and replace it.
Bugsquawsher is offline   Reply With Quote
Old 12-16-2004, 06:10 PM   #6
TheBlurLS1's Avatar
it's only been in there for about 12k miles
Old 12-17-2004, 09:38 PM   #7
SupahRich's Avatar
My '01 slave has the part # printed on the back side it, opposite side the T/O bearing is located. Can you make out any #'s all?
SupahRich is offline   Reply With Quote
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
