installation of shift light
ramairstyle00 I've got a couple of questions about your shift light......
1) what brand is that
2) was the install easy
3) was it a clean fit or did you have to cut into your pillar
4) what color is the light when it's activated
I've got a nice small autometer shift light mounted in the center of my gauges. The second picture shows what it looks like from the driver seat. Third picture is the RPM Activation module (it's tucked away, just not for the picture). These were taken a while back. Sorry about the picture sizes.
Cheers.
Cheers.
i found a awsome spot for mine, leave the bracket off the light, pull the gague cluster plastic cover back a lil and runn the wire up on top the arch and snap it back into place with the wire being held by the cover. it lays nice and flat on top the dash and its not in the way but easy to see without looking down.
1- the harlan shift light
2- heck yea
3- just pull the pillar, then pull the "hose" out thats in there
4- they can be a few colors, mines red
Ive seen pictures where someone took there gauge cluster apart and replaced the Skip shift light in the bottom right corner with the shift light. Looked really good(like factory) but im not sure how hard it was to install. Im sure if you search for it you can find it. If i get time i will look for it and post a link.
shift light
Ok, I found a pic of the shift light installed in the gauge cluster. It was in a post on another sight asking the same questions. Ther was not more info in the post. If you look at the other picture on the site youcan see some of the install.
In Cluster Shift Light
Originally Posted by ramairstyle00
quality costs money! this is a BRIGHT light with alot of features
What I ment was where did you get yours....where is the best pricing for those???
I believe the 2 popular shift lights harlan and raptor, are only sold new from there own web sites. You can search either to find the sites. harlan($50) is cheaper than raptop($85), I believe. I have a harlan in my AC vent also.
