the plastic white cup under the shifter
sorry guys im 18 so go easy on the way i talk/type
just got a 98 z28 m6 came from a civic
bought a pro 5.0 shifter and was looking at the installs and noticed thtat lil white cup that the shifters lil ball sits in, i have 75K miles on it and with the factory pice i can move the shifter forward/backwards about a 1/4 inch be for it realy moves in to gear, i think that white cup is trashed. what is it called, where can i get one. thanks
Its called an isolator cup and it is available at a dealer you ask for a T5 cup as T56s are only sold bonded to the offset lever( a much greater swap-out in the trans). You must use an epoxy glue to install it for a T56. Me most sure to clean all the old gle out when installing the new cup.
Got one if your interested.
1352-127-009= cup
glue+3M 2216 B/A Scotchweld.
1352-127-009= cup
Well mine was all tore up when i purchased my formula. I had 68k on it when i bought it. I dont know if it was the shifter or the ball. But the shifter would pull up out of the socket when i would try to shift fast. This is on a aftermarket hurst shift which i dont recommend to anyone. Put my pro 5.0 on and a new socket works like a charm now.
mine cracked and broke at about 40,000 miles.
where did I get the replacement part? the ford dealership of all places!
f'n gm would not sell the cup seperately. went to the ford dealer and asked for one for the 6 speed cobra. wham bam thank you mam. problem solved for a 10th the cost GM wanted. putz's.
