Centerforce or Spec or Ram? - LS1TECH
Thread Tools Search this Thread
Old 04-24-2005, 06:12 AM   #1
Default Centerforce or Spec or Ram?
Has anyone used the Centerforce Dual Friction clutch? The Spec 3 seems pretty stout but I've seen some bad posts about them.
vettesmakeemwet is offline   Reply With Quote
Old 04-24-2005, 06:30 AM   #2
Do you know there's something called a search button or where you born yesterday.
ls1mojo is offline   Reply With Quote
Old 04-24-2005, 06:37 AM   #3
Quote:
Don't you mean 'were' you born yesterday? And no I didn't know, I just joined LS1TECH a few days ago.
Old 04-24-2005, 06:43 AM   #4
The search feature is a well known valuable technical resource I recommend you use it.
Old 04-24-2005, 06:53 AM   #5
OK, so it looks like Spec 3 is the way to go. But should I get carbon or ceramic? Which will last longer? Also, my flywheel (Centerforce Steel) will only have about 1,000 miles on it when I install the Spec, will it need to be resurfaced?
Old 04-24-2005, 07:02 AM   #6
An organic friction material will give you better feel and street manners, which is ideal for the majority of drivers. A ceramic or tougher material (ie, kevlar) can easily support additional horsepower and rpm down the road however may chatter and have more of an on/off nature.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
