Noise comming from clutch??/suggestions on new brand
Old 07-09-2005, 11:03 PM
fletchls1's Avatar
Default Noise comming from clutch??/suggestions on new brand
So i just finished the install of a turbo and now im having problems with the clutch holding up...when i lay into it the clutch slips horrible and just drops to the floor..i end up picking it up with my foot... i did that a few times then the other day i got into my car and heard this noise that sounded like a rod, the only reason i know its nothing from my motor is because i can rev it up and it sounds perfect...it only makes the noise when i am moving....Could this be from my clutch?
Im wanting to replace the clutch, flywheel, master/slave cylinders.
I would like to hear what is working out the best for everyone and where i can pick them up the cheapest...
by the way, im wanting a clutch that will handle drag racing...
Old 07-10-2005, 10:36 AM
fletchls1's Avatar
t t t
Old 07-10-2005, 11:36 AM
conan's Avatar
For my blower set up jason @ TSP recomended the ram power grip HD with 910 disk, and a billet steel flywheel. Thats what I went with. 01-02 slave and I left the stock master. The slave is probly your problem with your pedel, you have to do the slave while the trans is out and you can do the master later if you decide to go that way. I'm happy with the clutch it grabs like a ****.
