Stuck Clutch
Missing So you are saying that the bleeder valve above the quick connect fitting is missing????? Then what is in there??? Crawl under there and I bet that the bleeder valve is there. It's right above the quick connect fitting for the slave, and I believe takes a 11mm socket.
I have the same problem. From the research I've done, it seems to be either the master or slave cylinder. Which one do you guys think it is? I think I might replace them both.
Which master cylinder should I get (if replacing the slave doesn't work)? Ram, McLeod, stock, other...?
John, is this you??? I know it is, but where you been??? Most Wanted BIOTCH, lol!!! Naw, you have to do alot of things at this point, read all my post and you will see what I have upgraded to, my first race from a dead, I burnt my clutch bad, twice and the other night, from a dead, I killed a WS6 and my clutch, atleast I won, lmao!!! So it was worth it, hit me and we can talk about what you need to do!!!
hella ****, Ram Powergrip w/Ram billet flywheel, adjustable master cylinder from Futral Motorsports, 2001 Slave cylinder, and relocation of braided lines under the car. Too much money though, this **** cost me hella!!! But it's gonna be worth the money, u rollin out this weekend, I never see you out???
Originally Posted by 408Maro
yea its missing,i know its weird huh,ive had teachers from my school check it out and its not there nothings there so i need to replace the master n slave as well 00ws6 it sucks,i just cant belive the delarships are ********
But anyways, I just bought a new master and slave from Texas Speed. They said it should be here by Friday. Hopefully I can put it all in this weekend and I"ll let you guys know if it fixes the clutch getting stuck.
cool let me know what happens,and also how much did that cost?
For the master and slave I paid around 302$. I bought the Ram adjustable master cylinder cause it was cheaper than the McLeod one which was 300 something.
