In your opinion, will a Z06 clutch hold up to what I will be doing?
Old 07-11-2005, 11:32 AM
baddogz28's Avatar
Default In your opinion, will a Z06 clutch hold up to what I will be doing?
My car has all the boltons right now, and this month I will be going to a TNT power ring setup (100 hp jets at first) and also adding a 233/239 @ 114 TSP cam and a Moser 9"... I am skeptical about aftermarket clutches (Spec) from reading all the horror stories on here about them, and I have beaten the **** out of my stock clutch which has 51k on it right now and is just starting to slip.
I know that the Z06 is supposed to be rated to 540tq , and I guess I will be right about there using the 150 hp jets on the TNT kit.
I will also be running MT et streets.
I did use the search button, but I am looking for opinions on whether a Z06 clutch is adequite for my setup.
Did I mention that I can get an OEM Z06 clutch + new flywheel, pressure plate and throwout bearing brand new for 368 + tax total?
Old 07-11-2005, 08:34 PM
glennster's Avatar
IMHO it won't work long or at all.My Z06 clutch had less then 10k on it when I installed the cam and got low 12's,it started slipping at that level.If i slipped it slightly off the line for a good launch it would flare up a few hundred rpm on the gearchange but be OK after an hour cool off.I installed a ram HD w/billet fly and never looked back.You get what you pay for and if you race the car you need a better clutch.
Old 07-11-2005, 09:21 PM
n2ojunkie's Avatar
I would say no. I broke the ring on the dampner springs on the clutch disk on 3 different ones with just a 100hp TNT f1 kit and thats on bfg dr's. I admit I drive my cars hard but I still dont think it will hold up. I put a cartek in and its doing fine after 2 yrs and 2 transmissions, 1 ds, 1 tq arm. So you know where I would go, but Iam looking at something else just to see whats out there.
Old 07-11-2005, 10:48 PM
pushinfreight's Avatar
You will break it. Spend the money and step up if you do not you will have to later. 400 rwhp and a hot day will wreck havoc on the stock clutch.
Old 07-11-2005, 11:28 PM
wrencher
wrencher's Avatar
No a Z06 wont hold.Nitrous, you need a CLUTCH. Dont buy a spec either & you'll be OK.
You heard my car w/ the same cam.I have a McLeod single in there now, slips @ WOT, w/ 10 K & lots of runs though. Twin disc here I come.
Old 07-12-2005, 11:31 AM
baddogz28's Avatar
Thanks guys, that helps a lot.
Old 07-13-2005, 11:05 AM
6600 rpm clutch dump of death Administrator
J-Rod's Avatar
I'd recommend looking at the Textralia clutch.
Old 07-13-2005, 03:34 PM
dug
dug's Avatar
It might last if you granny shift it but that would be lame.
Old 07-15-2005, 07:59 AM
JoeyGC5's Avatar
Same damn thing happened to me with only 330rwhp/360rwtq
Quick Reply: In your opinion, will a Z06 clutch hold up to what I will be doing?
