stuck in 4th gear! need parts.
hi,
i was racing on the highway and when i shifted to 4th it went in smooth but never got out, it got stuck in 4th. it drives fine in fourth only, the clutch is good and everything. i havn't looked at it yet, but i would think maybe syncros or 3-4 shift fork, maybe something else?
if i need to upgrade to stronger parts like billet and steel shift fork which sponsor can i get these parts from and what would i need exactly?
could you please list all the parts needed to be upgraded and from which sponsor.
btw, i have a SPEC stage III clutch, mcleod adj master, 01 slave, and steel flywheel
thank you
thank you
Originally Posted by SSHOTROD
whateva it is, its catching. Im stuck in 4th too. Ill be pulling the trans apart monday or tuesday and ordering parts soon after.
im proshifted now so i dont know what parts you need but good luck
call alan at fms for parts, he's a t-56 guru
Most likely broken synchro keys or shift fork damage.
Basic rebuild kit 150-199
Billet keys (upgrade. regular stamped keys are inlcuded in the rebuild kit)75-99
steel shift fork 50
Check with either D&D performance, The Gear Box or G-Force for the parts. I don't think that any of the sponsers ell T56 parts.
steel shift fork 50
