What to replace stock clutch with?
My clutch is going out on me. My SS is a 98 with 77K miles on it. I don't race it all, it's my cruiser. However, I couldn't resist modding the car with exhuast, shorty headers (I live in CA), lowering springs, and basic bolt-ons. Anyways, my question here is what upgrades can I do to the clutch if I dont want to go back to the stock clutch? I am fairly new to upgrading clutches and being the hot rodder that I am, I don't want to replace the stock clutch with a stock one unless I have to. I don't want anything too crazy but something thats better than stock. ANy suggestions would be extremely helpful!
But this is an area this is going to require plenty of research; I've been on this manual transmission board for quite awhile trying to first diagnose my problem, and then trying to learn all I could about the clutches that are out there and reading people's successes/problems with them. Every clutch had at least one person that loved it, and one that hated it. There is no "perfect" clutch for that very reason. Just do your research so you can make the most educated decision possible for the goals you have in mind.
I'm in the same scenario (2000 Z28, intake/exhasut mods). What was recommended to me by just about everyone I've spoken to so far was the Z06 upgrade clutch. Comes with clutch, pressure plate and a lighter/stronger flywheel. You'll definitely want to upgrade the slave cylinder at the same time. Master, not a necessity, but certainly won't hurt.
id recommend either the zo6 clutch, spec 2 or ram oem replacement......all better than stock. If your not racing and need it to last then they are all good choices. go ahead and upgrade the slave since your already there. If your daring, then do the master cylinder and drill mod too.....Some shops sell the zo6 kit for 343 plus 45 for shipping.
Originally Posted by rush7
I'm having the same problem with my clutch right now and I'm going with a RAM Powergrip HD...you might opt not to go for the HD yourself, as the non-HD version is more streetable...I'm also replacing the hydraulics (which is actually the main cause of my problem, not the clutch itself) because our 98s suck in that realm. I will likely post my results upon completion of the install; wish I had an actual product opinion to give you right now.
Got the McLeod Twin Disk in now and I'm MUCH happier with it... well worth the money.
Appreciate all the info. Thank You. Have you all seen the Z06 clutch package that SLP is selling? It includes an LS6-style OEM clutch disc, a self-adjusting pressure plate and a SLP billet steel flywheel...all for $849.95 plus s/h. Is this a good/fair deal with what it includes? or does someone else know where we can get Z06 clutch for cheaper?
The SLP unit is about $500 over priced. You can get one from Jim Pace, or from here: http://www.sdpc2000.com/catalog/2239...e-Assembly.htm for $350 US. Or any GM dealer parts department should be able to get it for you, which might be better if you are part of a club with a parts discount at a local dealer.
WOW. I couldn't believe the price difference. I completely forgot about SDPC. appreciate all the info. Looks like ill be going the Z06 route through SDPC.
Ill post the results....Thanks.
Originally Posted by Tranzor_Z28
I wish you luck with your Powergrip HD... here's what mine looked like after around 800 miles and exactly 8 track passes:
ouch...did you replace the flywheel and supporting stuff at the same time or just the clutch kit? i've heard of people really tearing stuff up if they don't do a full swap, but damn...800 fricking miles....that's maybe 3 weeks worth of trips to work and back for me....ugh
PR Director
Originally Posted by STS SUPERCAR
Centerforce or z06 clutch which is better?
As far as what is the best aftermarket clutch, the answer is going to vary based on who you ask. For me the best answer hs been a Ram 6130 disk with a 402 pressure plate and a stock flywheel. I have literally hundreds of 1/4 mile passes some on slicks, some on DRs and 60K miles on this clutch. I paid 350 for it and just had it rebuilt for 190.
Bottom line there is no "best" clutch.
