HELP: Clutch/Tranny Probs
Old 07-18-2005, 03:03 PM
MachoCamacho's Avatar
Default HELP: Clutch/Tranny Probs
Alright, so recently i've noticed its been really hard to shift into 2nd gear, then it started with every gear, including 1st(maybe even mostly 1st and reverse...), cant do any "punch it" runs lately that succeed with shifting, also when i put it into 1st with no brake the car is trying to move forward, any help would be awsome....synchros or slave cyl, i dunno, this is the 00 slave cyl still i think, i did have the master cylinder replaced though when i got the car.
Old 07-18-2005, 03:06 PM
1madss's Avatar
The car trying to move while you have the clutch in is a dead giveaway that the clutch is not disengaging fully. Most likely a hydraulic issue. I would start with bleeding the system. If that does not cure the problem, I would look at the slave.
