1st gear bog?
1st gear bog?
Just curious, but have been playing around with launching, and when I put in first gear and normal drive everything fine. If I give it some gas, like 3krpms, dump clutch tires spin. If I try to let up on clutch fast, and mash down on gas pedal, car bogs then goes. What gives?
Well its what happens when you are asking for torque. If it breaks the tires free, it relieves the torque through spin. If you set the tires, the trans is getting the torque to the ground(bogg) and working the engine.I think I understand what you are asking.
so how do I properly get a good launch with little wheel spin and no bog? mods on page 5 at www.cardomain.com/id/ozorowsky
