New Flywheel / Clutch
Hi all, just installed the TPIS single mass flywheel / clutch assembly this weekend and had a question. Is a little burning smell okay, normal at first after installation of a new clutch and flywheel? When I first cranked the car it smoked for about 2 minutes. After crawling all over the car and ruling out any leaks I figured it was either the header wrap burning in or the clutch ( I also installed headers at the same time). After a bit, I decided it was the clutch. I took her for a spin around the block and after a few miles the smoke / dust was gone and only a little of the smell remained. It didn't feel as if the clutch was slipping at all. A couple more short trips around town and the smell got better with each passing mile driven (less) but it's still there. What do you guys think? Pull it back apart to look at it or let it go for another day to see if it improves. What's the worst that happens, I burn up the clutch? I've installed one other clutch before and don't remember it doing this. I followed the directions although now I am a little suspect of the torque wrench I used to tighten down the clutch. If I didn't torque the clutch to the flywheel high enough, would that cause the clutch to slip, thus the burning smell?
Thanks
Thanks
