Master Cylinder Hydraulic line will not go into slave... - LS1TECH
Thread Tools Search this Thread
Old 07-26-2005, 02:25 PM   #1
Scalpel's Avatar
Default Master Cylinder Hydraulic line will not go into slave...
We're trying to install the master cylinder hydraulic line into the slave cylinder port. It will not go in.
Should we crack the bleeder open?
Scalpel is offline   Reply With Quote
Old 07-26-2005, 03:06 PM   #2
I've heard that it helps, but I was able to get mine on with some pretty significant force and a pair of leather gloves.
NOBR8KSS is offline   Reply With Quote
Old 07-26-2005, 03:16 PM   #3
Scalpel's Avatar
So yours required a "lot" of force to get in?
Old 07-26-2005, 04:06 PM   #4
PR Director
Deech's Avatar
I didn't have to apply that much force to get the line in. Are you just replacing the master and did not drop the tranny?
Deech is offline   Reply With Quote
Old 07-26-2005, 04:39 PM   #5
Scalpel's Avatar
Putting in a new motor in DragonZ28s car. Tranny was bolted to the new engine. Engine/tranny installed in the car. This is the last connection, plugging the master cylinder hydraulic line into the slave connection. It just want to go in.
Old 07-26-2005, 06:04 PM   #6
I would make sure none of the prongs inside the quick disconnect on the slave are not bent. I never had any problems connecting it.
GETSOMZ28 is offline   Reply With Quote
Old 07-26-2005, 06:10 PM   #7
LS1TECH Sponsor
Steve Burger's Avatar
Open the bleeder on the slave and try that. It helps to relieve pressure sometimes.
Steve Burger is online now   Reply With Quote
Old 07-26-2005, 07:17 PM   #8
The bleeder valve on the slave must be open in order to plug in the line.
Ferocity02 is offline   Reply With Quote
Old 07-26-2005, 07:46 PM   #9
ninobrn99's Avatar
hmm...mine went in with ease. i just found the hole and pushed.....not hard at all either.
ninobrn99 is offline   Reply With Quote
Old 11-18-2007, 08:50 PM   #10
99SilverZ's Avatar
Quote:
Where is the valve on the slave? I'm having trouble inserting the m/c line too.
99SilverZ is offline   Reply With Quote
Old 11-18-2007, 09:37 PM   #11
Cracking the bleeder will help but it is not needed. Put an open ended wrench around the braided line on top of the quick disconnect fitting so you can apply more force and then just push.
slowscott is offline   Reply With Quote
Related Topics
Thread Thread Starter Forum Replies Last Post
WTB Clutch master cylinder line Alien Parts Wanted 2 09-15-2016 08:55 AM
Slave cylinder disconnect tool ADM Manual Transmission 2 05-23-2015 02:42 PM
Cannot get hydraulic line back into T56 rberg89 Manual Transmission 3 08-17-2014 09:57 AM
slave cylinder bore size ? 1 FMF Manual Transmission 2 06-01-2013 10:10 PM
Hydraulic Clutch Line Problem twistedv Manual Transmission 0 12-29-2012 01:15 PM
Tags
1999, 99, camaro, connect, cylinder, disconnect, hydaulic, hydralic, hydraulic, line, ls1, ls1tech, master, nobr8kss, reinserting, slave, t56, trouble
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
    Get answers from community experts
What's your question?
Send
